Converting Dimmer to Standard Switch Problem
mike_bike_kite
by mike_bike_kite » Mon Mar 19, 2018 12:50 pm
I thought the two bulbs had gone in my son's bedroom so swapped one bulb and tried again. After fiddling with the dimmer for a while the bulb I hadn't swapped flickered on then went out. I figured it must be the dimmer switch itself.
I don't particularly like the dimmers in my house and my teenage son does smack the poor things every now and then so I figured it would be better installing a normal switch.
The existing wiring on the dimmer was:
  • C one blue wire and one black
  • L1 a red wire and a yellow wire
  • L2 a single red wire
I wired it up the same with the new switch but neither light comes on. The fuse isn't blown. I do have a multi-meter if required.
Any ideas?
Re: Converting Dimmer to Standard Switch Problem
by Mr White » Mon Mar 19, 2018 6:39 pm
I will guess as there is no specific rule as to what colour goes where.
Swap L2 with C
And always take pictures.
I will also guess the light can be turned on / off from another location?
mike_bike_kite
by mike_bike_kite » Mon Mar 19, 2018 7:28 pm
There's only one switch in the room and two little halogen bulbs in the ceiling. Am I still OK to swap the wires over?
Thanks for replying by the way!
by Mr White » Mon Mar 19, 2018 10:12 pm
As I said previously there is no specific rule as to what colour does what or where it should go, but, the fact you have a twin and earth and a 3 core and earth implies there is or was another switch, pull cord perhaps?
Yes, still swap them over (The red must stay as it is now, on its own)
mike_bike_kite
by mike_bike_kite » Tue Mar 20, 2018 11:19 am
OK swapped L2 and C over but still no lights. On the plus side I haven't blown all the fuses yet or electrocuted myself!
I was curious about the other switch you mentioned and did eventually find a pull cord hidden at the back of a fitted wardrobe.
Any idea what should I try next?
by Mr White » Tue Mar 20, 2018 9:54 pm
The way a 2 way switch is wired (in a nut shell) is one single wire at the top (C)
and two wires in each of the bottom terminals.
So if you had a red single it should be on its own at the top in C (common)
when you swapped L2 and C around, make sure that both wires in L2 are actually making a connection, no harm in checking L1 either.
Since it was working before you changed it, and there are no electronics involved, it has to be a airing configuration error, but you are sure you have them right, so it must be a connection (or not) problem.
Skid Sprocket
by Skid Sprocket » Wed Mar 21, 2018 3:44 pm
With a 3 core & earth 2 way switch wiring the yellow should go to the C (common) on both switches with red and blue/black (from the same 3 core cable as yellow) to L1 & L2 and the other 2 wires (from the twin cable) into L1 & L2. This twin cable goes to the light fitting and will not show at the pull switch.
The 3 core cable is really just linking the two switches.
by Mr White » Wed Mar 21, 2018 7:50 pm
Skid Sprocket wrote:With a 3 core & earth 2 way switch wiring the yellow should go to the C (common) on both switches with red and blue/black (from the same 3 core cable as yellow) to L1 & L2 and the other 2 wires (from the twin cable) into L1 & L2.
Sorry to say but as i have said before, there is no specific rule as to what colour goes where, so to say Yellow must go to the common is not a definitive response, since it depends on what colour who ever wired chose to use.
And since the op did say he had a black and a blue, and a red and yellow already as pairs........
by Mr White » Wed Mar 21, 2018 7:52 pm
Mike bike kite. The pull cord you found, any possibility you could gently take its cover off (it will unscrew) and see what colour wire goes to what terminal?
mike_bike_kite
by mike_bike_kite » Wed Mar 21, 2018 8:33 pm
I'll have my next attempt tomorrow morning when it's light. I'll have a go at seeing what the connections are to the ceiling switch but it's at the back of a top cupboard and I'm not sure I'll fit.
Would it help clear up things if I used the multimeter on the various wires?
mike_bike_kite
by mike_bike_kite » Thu Mar 22, 2018 11:09 am
I've attached a picture of the wiring to the other light switch. It's quite difficult to get too so this is probably the best image I can get. Hope it helps.
by Mr White » Thu Mar 22, 2018 7:02 pm
Sorry, I am busy today, but what happens if you "switch on" the pullcord?
collectors
by collectors » Sun Oct 07, 2018 5:41 pm
Looking at that picture & assuming it is joined to your switch, but it doesn't sound right to what you was saying on your connections. IE:
"The existing wiring on the dimmer was:
L2 a single red wire"
The reason i say this is the pull switch has the red as common "C" & wouldn't work with you connections as the red would have to be in C at your switch
if so & at the switch, take the red from the 3 core & put it in terminal C. Now you have 2 cables left from each cable at the switch. Put the wellow from the 3 core & the red from the twin in L1. Now put the remaining 2 cables in L2 & test.
If its still not working there might be a fault with the pull switch. To test this, take the red & blue out the pull switch & put them together in a conector, test again.
by Mr White » Sun Oct 07, 2018 9:55 pm
Collectors, I asked mike_bike_kite a question to which he has not replied, I am willing to bet that he will not reply to you either...........considering I asked over 6 months ago.
collectors
by collectors » Mon Oct 08, 2018 12:43 pm
[quote="Mr White"]Collectors, I asked mike_bike_kite a question to which he has not replied, I am willing to bet that he will not reply to you either...........considering I asked [b]over 6 months ago. [/b][/quote]
Ah! your right, i just clicked on new posts & for some reason this one came up. Didn't check the date. lol. I take it that the problem was solved or he is no longer with us?. :)
It is currently Fri Nov 22, 2024 3:18 am
