Earthing a Steel sink
SWEEP
by SWEEP » Tue Aug 28, 2007 10:06 pm
I am about to fit a stainless steel sink and understand that I need to earth the sink when fitting it.
Any advice gratefully received on whether this is needed.
Drives47
by Drives47 » Thu Aug 30, 2007 1:03 am
I think it's a legal requirement. I go to a lot of new builds and anything that might conduct electrickery is earthed. Steel sinks and baths now have a little tab on the bottom to hook an earth connection to. Mainly sinks because of thier proximty to electrickery. Hook a connection from the tab to the cold water mais feed in. But check this with a plumber. Don't take the word of a driver on it!
SWEEP
by SWEEP » Fri Aug 31, 2007 5:02 pm
[quote="Drives47"]I think it's a legal requirement. I go to a lot of new builds and anything that might conduct electrickery is earthed. Steel sinks and baths now have a little tab on the bottom to hook an earth connection to. Mainly sinks because of thier proximty to electrickery. Hook a connection from the tab to the cold water mais feed in. But check this with a plumber. Don't take the word of a driver on it![/quote]
Thanks mate I am sure you are right.
By 47 I assume a class 47 loco? Or am I way off the mark?
Undermount-Sink
by Undermount-Sink » Thu Sep 06, 2007 6:20 pm
I think Drives47 is expalined pretty much better but i have one more suggetion for you whenever you earthed your try to underground the earthing wire iit so it will safe for your childrens.
It is currently Sat Nov 23, 2024 8:48 am
