Chasing Cables into Solid Wall for Wall Mounting TV
newtdiy
by newtdiy » Sat Mar 31, 2018 12:17 pm
Please can you give me guidance on chasing electrical cables into solid walls.
Wall mounting a TV onto solid wall and chasing the cables into the wall.
What are the regulations or recommendations involved with the job?
Would it be consider safe to directly plaster the cables into the wall without using a conduit to protect the cables?
Would all purposes powder filler be the correct choice to fill in the chased wall area?
Thank you.
Any info on this subject would be very useful.
Re: Chasing Cables into Solid Wall for Wall Mounting TV
by Mr White » Sat Mar 31, 2018 10:19 pm
If you put the cables in trunking or conduit, then at a later date you can easily change / upgrade the cable without any damage.
It's your choice what you use to make good.
newtdiy
by newtdiy » Sun Apr 01, 2018 4:48 am
Thank you. An electrician did not chase the cables into the wall and the job looked a mess - I had to get the complete job redone. He presented himself as having experience in wall mounting TV and charged me accordingly - £400 . It has been a nightmare.
chriscba
by chriscba » Sun Apr 01, 2018 11:09 am
Just be careful where the existing cables are in the wall, cables run vertically from sockets.
They also run horizontally sometimes
It is currently Sun Jan 12, 2025 2:35 am
