Bathroom Extractor Fan
MattR
by MattR » Wed Aug 29, 2007 10:57 am
I have recently moved into a house, which is approx 10 years old. I am looking to replace the ceiling mounted bathroom fan, which currently operates from a pull cord in the bathroom. I have purchased a new ceiling mounted fan from B&Q (model number NDX100BC). The current connections into the fan are simply live and neutral and the connections in the pull down cord terminal are live, Neutral and earth. I am looking to extend the cable by approx 1 metre and channel it down the plasterboard to a surface mounted switch located outside the bathroom.
Can I use a simple junction box to connect the existing wires (live, neutral and earth - which are currently wired to the pull down cord terminal) and run a length of identical cable from the junction box to the back of a surface mounted switch?
The bathroom light is also connected to a ceiling pull down cord. Would it be possible to do the same thing and maybe channel both cables down the wall and connect them to a 2-gang switch with one switch operating the bathroom light and the other switch operating the bathroom fan?
It does recommend using a double pole-isolating switch. Any advice would be greatly appreciated.
Many Thanks
Matt
by sparx » Wed Aug 29, 2007 8:31 pm
Hi mattR the principle is fine but remember ANY electrical work in a bathroom is covered by Bldg regs part p so either got to pay a fee to LABControl or use a registered leckie!, regards
SPARX
MattR
by MattR » Wed Aug 29, 2007 9:31 pm
Thanks for the reply sparx,
Could you please explain to me what a double pole isolating switch is and how it would be different from using a normal switch?
Would it be acceptable to carry out the work and have it immediately checked by a qualified leckie?
Matt
by sparx » Thu Aug 30, 2007 9:35 pm
Hi agn. D.P. =both Live & Neutral go through a 'pole' of the switch, eg a standard light sw is 'single pole' breaking only the Live conductor, a 'fan isolator' sw. which is used when there is a timer over-run fan fitted is a
'triple pole' device breaking L, sw-L, & N for total circuit isolation.
I'm afraid just 'getting it checked' does not comply with regs. legally either sparkie who can self-certify must do the work or you must pay the OTT fee to LABC, sorry, regards SPARX
It is currently Thu Sep 19, 2024 11:39 am
