Garden Tap Repair After Renewing Due to Front Damage to old one
Leec1987
by Leec1987 » Fri Apr 13, 2018 10:28 am
My garden tap was damaged during the frost recently so I bought a new one and some PTFE tape, fitted the tap fine, that is all working fine.
During removal of old or install of new there was slight movement (despite my best effort with grips) which has loosened the mains fixing behind tap and water now leaks out of joint.
I am not so confident to simply attempt to tighten this one and thought I'd seek help as it may need to be replaced or done with proper sealant.
Can anyone look at the attached picture and advise best course of action.
NathanIfans
Re: Garden Tap Repair After Renewing Due to Front Damage to old one
by NathanIfans » Mon Apr 16, 2018 12:36 pm
I wouldn't replace the tap fixing. Remove the fitting, apply PTFE tape to the mains tape, and fix the tap connector back on. Should do the job
It is currently Fri Nov 22, 2024 9:35 am
