Red Tiled Downstairs Subfloor Help Needed
Adamneedshelp
by Adamneedshelp » Fri Apr 13, 2018 7:27 pm
Hi there. I’m renovating a house and downstairs the subfloor is made from these red tiles. Like pamments but not as nice. It’s a 60s house in the U.K. so hopefully someone knows what I mean. I want to lay vinyl flooring everywhere and it’s obviously not suitable because of the unevenness.
Can I use self levelling compound on these tiles? I would assume not but that would certainly be easiest...
Failing that could I screed over them with sand/cement? I’m not sure if it would adhere?
Any help or advice is welcomed, thankyou.
NathanIfans
Re: Red Tiled Downstairs Subfloor Help Needed
by NathanIfans » Mon Apr 16, 2018 12:33 pm
If the tiles are too solid to lift up to screed the floor properly, then I see no issues in using self leveling on top, to flatten for vinyl
One thing - if screeding or using self levelling compound, you will nedd to make 100% sure that the base you are laying on is totally solid otherwise movement could occur and the screed/self leveller will move and crack
Ultimately, it's best to lay on a firm solid base so removing the tiles may be the best solution
It is currently Fri Nov 22, 2024 9:37 am
