Wiring Advice for 3 Lights Turned on by 1 Switch
ddub7666
by ddub7666 » Mon Apr 16, 2018 1:00 pm
I have attached a schematic diagram for 3 lights to be turned on at the same time by 1 switch. Is the wiring correct?
Re: Wiring Advice for 3 Lights Turned on by 1 Switch
by Mr White » Mon Apr 16, 2018 10:16 pm
Your question is "is the wiring correct?"
The answer is No.
Lamps 2 & 3 Will be permanently on and lamp 1 will depend on if the switch is on or off.
Your drawing is clear and concise, which should also mean if you look harder, with the information I have given you should locate your error.
It is currently Fri Dec 27, 2024 9:08 pm
