Baumatic BT2760SS Main Oven Thermostat Replacement
Tayler
by Tayler » Thu Apr 19, 2018 2:50 pm
Baumatic BT2760SS (DUAL ELECTRIC OVENS - GAS HOBS):
? How to access and remove/install Main Oven Thermostat/switch and connected Oven Temperature Probes.
? How to access behind control knob fascia (fascia firmly fixed - no screws/clips in sight).
?How to access the length of connecting wire from Probes in oven to switch.
Thank you.
Re: Baumatic BT2760SS Main Oven Thermostat Replacement
by Mr White » Fri Apr 20, 2018 12:14 am
This is an electrical forum, we can help with the supply to the oven but not help with the oven itself as it is a "white goods" item.
I would suggest you try a UK white goods forum
It is currently Sat Jan 11, 2025 10:44 pm
