Door Hinges for Replacement Kitchen Back Door
DecnDor
by DecnDor » Sat Apr 21, 2018 9:30 pm
Hi, I am in the process of replacing my heavy duty brass door hinges on my back kitchen door. In order to do the job properly I have to remove the door.
then In order to drill the screw holes accurately I have invested in a set of self centring hinge drills. Now the screws provided with these hinges are a No 10 for which is recommended a .190" drill diameter which is approximately 3/16" having selected the appropriate self centring drill I foiund that the the diameter of the spring loaded guide was smaller than the holes in the hinges and therefore would not be suitable. Do you know if they sell special self centring drills for this situations. The only other alternative is to go for bigger diameter screws but I am not sure if this is a good practice. Any advice on this would be welcome.
Sometimewoodworker
Re: Door Hinges for Replacement Kitchen Back Door
by Sometimewoodworker » Tue May 08, 2018 3:05 pm
DecnDor wrote:Hi, I am in the process of replacing my heavy duty brass door hinges on my back kitchen door. In order to do the job properly I have to remove the door.
There is a simple work round. Use a larger self centring drill but do not go more than a couple of mm deep, then you will have a conical depression, just use the correct size of drill bit to drill the full pilot hole.
Problem solved.
It is currently Thu Jan 09, 2025 12:15 pm
