Connecting 110mm Plastic Drain to Brick Inspection Chamber
Ask questions and find answers on a range of subjects relating to self build projects
Winkers
by Winkers » Mon Apr 30, 2018 7:17 pm
I need to connect a plastic 110mm drain to an existing brick inspection chamber. Should I break into the chamber directly with the plastic pipe or should I put in a piece of clay pipe to make a good mortar seal then use a PVC coupling between the clay and plastic?
As all the existing pipes in the chamber are clay I am concerned about obtaining a good seal with the plastic pipe.
It is currently Tue Nov 26, 2024 11:23 am
