shower pump problem
FUBAR
shower pump problem
by FUBAR » Wed Aug 29, 2007 6:46 pm
Hi guys ,
Having a problem with our duraspeed pump to our shower .
The pump starts up when turning shower on but after a while it just cuts out and stops pumping ... when leaving a while later can start up the shower and again and again shortly after cuts out again . Any suggestions or advice here before looking for a new one , Was hoping i maybe to repair , have repaired to save cost of replacing .
it's a New team duraspeed 044516 .
thanks for your replys in advance .
rockallplumbingbmth
hmmm
by rockallplumbingbmth » Mon Sep 03, 2007 10:33 pm
have you tried it on separtly hot and cold on the shower
it must be over 3 years old
have you got a negative head switch ( do you have to pull a cord to start the shower? )
have you checked the filters in the pump connections they might be scaled up!
i hope some of this might lead you in the right direction
rockall plumbing bournemouth
It is currently Sat Nov 23, 2024 2:54 pm
