Mystery Box and Cable on Outside Wall
Ptx79
by Ptx79 » Tue May 15, 2018 7:15 pm
On the outside of my house, next to the front door, I've had a mystery box containing a cable that I don't know what it's for.
Its located to the left of my front door. It's not for a light as there already is one on the other side of the door. Also every house down my street and the surrounding area has one.
I want to remove it (push it back into the wall) and cover it with a house number plaque, but I'd like to know what it might be for first! My local electrician wasn't sure, which surprised me.
Cheers guys
Re: Mystery Box and Cable on Outside Wall
by ericmark » Wed May 16, 2018 6:31 pm
Looks like coax, you can have 5 or 12 volt on coax to work an LNB or mast head amp, as to why at door can only guess, maybe was intended for door entry system. I would test to see if any volts, if not then OK to hide.
It is currently Sat Jan 11, 2025 10:49 pm
