Resin Pointing on Patio and Loose Grains on Top
NoiseManUK
by NoiseManUK » Sat Jun 09, 2018 7:02 pm
Evening all, hope you are well.
Looking for some advice on a re-pointing job I had done last week.
I've had the patio repointed using a resin bond (the granule looking stuff). I'm a bit concerned because the grains seem to be loose on the top layer of the pointing - if that makes any sense.
For example, if you run your finger along the joint, you will get a few grains come away.
Just wondering if I should be worried or if this is just normal for this type of pointing as it beds in.
Thanks in advance!
Andy
It is currently Fri Feb 07, 2025 10:55 am
