What Paint to use for Painting Interior Concrete Blocks
tomq42
by tomq42 » Mon Jun 11, 2018 11:24 am
I have a garage with interior walls made from *paint grade* concrete blocks.
So clearly I can paint them :-)
Question is what do I use?
Do I use exterior smooth masonry paint, or do I use standard interior emulsion? Interior emulsion is presumably designed for smoother surfaces, but I don't need the weather/sun protection of the exterior masonry paint.
Also, do I need to seal at all? Do I even need a mist coat, since the blocks won't such up moisture as much as fresh plaster would? What about the mortar?
Any other tips welcome.
Thanks.
pjohnson1970
Re: What Paint to use for Painting Interior Concrete Blocks
by pjohnson1970 » Thu Jul 05, 2018 1:20 pm
Personally I would recommend the Masonry paint as you mentioned it gives you the weather protection although both choices have their pro's and con's I would choose masonry.
It is currently Sun Nov 24, 2024 2:11 am
