Kitchen Unit to Plastered Wall
myself
by myself » Thu Aug 30, 2007 9:27 am
I've recently moved in to anew house and I need to put up a (wall mounted) kitchen unit.
Now the wall sounds hollow :shock: , when I knock around. The unit is heavy and a bit concerned. DO I use normal plasterboard screw fittings or should I use something more stronger?
Hope to hear...before the wall collapses :D Ta.
kbrownie
by kbrownie » Thu Aug 30, 2007 12:53 pm
Hi Myself,
I have already addressed a few post yesterday regarding the same type of problem.
Don't like to sound repetative and I don't sell them!
But speaking from experience, I put a kitchen up in my house about 5 years ago and that had stud hollow walls. I used what's called "Hollow Wall Anchors" They came in all type weight duties. Available from DIY stores, builders merchant, iron mongers and so on. The good news for both of us is; that my wall units are still up and full of cups, plates, glasses etc....
So I'd recommend them with confidence.
Hope this was of use
Kind Regards and Good Luck
KB
kbrownie
by kbrownie » Fri Aug 31, 2007 7:36 am
me again
sorry didn't mention can buy brackets to fit on back kitchen units that hook on, from unit to wall and no need to screw straight through unit it's self.
KB
It is currently Sat Nov 23, 2024 3:03 pm
