External electrics spur from GET IP66 weatherproof socket
Padster72
by Padster72 » Sat Jun 23, 2018 5:10 pm
We have a GET IP66 weatherproof socket outside the kitchen, and I am hoping to take a spur of that socket to run a redundant junction box (to be used for later), a set of deck lights, and a couple of wall lights (3 spurs in all).
Is this easily done? What do I need to do this?
Re: External electrics spur from GET IP66 weatherproof socket
by Mr White » Sat Jun 23, 2018 9:29 pm
Electricians often make things look easy, simply because of the years of training and experience, in your case I strongly recommend you call an electrician to do the job safely for you as it is not as easy as you seem to think.
It is currently Thu Nov 21, 2024 4:39 pm
