Toilet Cistern Overflowing Unless Float Manually Lifted
Phil33
by Phil33 » Sun Jul 01, 2018 9:48 am
Not sure if anyone will be able to help me as it looks like I can't add photos (other than via Photobucket etc). My toilet is overflowing unless I manually lift the float. There seems to be friction between the lever and the threaded rod which sets the float height / water level. The valve is similar to this but side rather than bottom entry: [urlhttps://www.lowes.com/pd/KOHLER-Revival-Rialto-San-Raphael-10-in-Toilet-Fill-Valve/1000144753][/url]
I bought a new valve assembly but it is too big to fit in my rather small close coupled tank. It looks like I need to bend the lever slightly so it does not press so hard on the threaded rod but it looks to be brittle plastic which would probably break
It is currently Fri Nov 22, 2024 7:57 am
