Replacing Light Fitting Using Existing Fitting
bert191
by bert191 » Tue Jul 17, 2018 1:47 pm
I've taken down a light fitting and from the ceiling is a brown blue and earth wire. These go directly down to the bulb, I've found a new light fitting with 3 terminal blocks live neutral and earth, can these just be fitted to the existing cable from the ceiling.
Re: Replacing Light Fitting Using Existing Fitting
by Mr White » Tue Jul 17, 2018 6:37 pm
Cables go to a lamp holder not the lamp (Other wise you could not replace the lamp)
So long as you connect the cables to the correct terminals, I can not see a problem.
It is currently Sun Jan 12, 2025 12:49 am
