End of Loop Ceiling Rose and Working out Switched Live
8 posts   •   Page 1 of 1
Rlupton
by Rlupton » Tue Jul 17, 2018 1:50 pm
Good afternoon all,
I am having a little trouble fitting a new light fitting to replace an old ceiling rose. The wiring in my flat is all old (black and red), but I have changed a few so far and all been fairly straight forward. However I've come to the last room and there are two of each wire (black, red and earth) rather than one in all the other rooms. I'm unsure which cable should go where, am I right in thinking one of the black wires is the switch live? If so is there a way I can work out which one it is?
Thanks for your help in advance.
Old cables
Old cables
New light fitting
New light fitting
Re: End of Loop Ceiling Rose and Working out Switched Live
by Mr White » Tue Jul 17, 2018 6:41 pm
You can either follow the cable run to see which one goes to the switch or use a multi meter.
If you haven't got a multi meter why not, do you use a knife to turn screws? You always use the correct tool for the job in this case you need a multi meter. (One can be had for less than £10)
Rlupton
by Rlupton » Wed Jul 18, 2018 9:40 am
Thanks Mr White. One like this?
https://www.screwfix.com/p/lap-mas830b- ... 0wod8WcPaw
My other question being, once I have identified the switched live, how would the old wiring be arranged in to that new fitting?
Would I be right in saying the black switched live would connect to the brown live wire? Other black neutral to blue. Then earth to earth, then connect the red live wires together separately? Like pic below?
Rlupton
by Rlupton » Wed Jul 18, 2018 10:29 am
Thanks Mr White. I thought that was what I would have to do. Like one of these?
https://www.screwfix.com/p/lap-mas830b- ... 0wodroEGMg
Once identified, does the switch live go to the neutral on the new fitting, as below?
by Mr White » Wed Jul 18, 2018 6:55 pm
The meter you have linked to will be acceptable for the task you need to do. Lots of tutorials on youtube. You will soon wonder how you did with out it.
Yes the diagram is correct.
by ericmark » Thu Jul 19, 2018 3:03 am
As you seem to have worked out, last one is easy, red to red and one black is neutral the other is switched line. With bayonet bulbs no real problem. With screw bulbs the centre pin needs to be line and screw neutral so some testing is required.
Rlupton
by Rlupton » Thu Jul 19, 2018 10:20 am
Thanks guys, now to buy and work out how to use a multimeter!
by Mr White » Thu Jul 19, 2018 5:28 pm
As I have said, there are lots of tutorials on YouTube. But "practice" elsewhere first, as electricity has no prejudices, it kills anyone.
It is currently Sun Jan 12, 2025 12:56 am
