Combi Shower and District Heating With Tap Connected to Both Hot and Cold
penultimatum
by penultimatum » Sun Jul 22, 2018 2:20 pm
Hi. I planned to install a mixer shower in my bathroom and connect hot and Cold of the taps feeds, which I have done in a previous house.
However, inspecting under the bath I can see the hot tap is connected to both the hot & cold water via a T-piece valve. Is this because we have district heating and have hot water pumped to our house? What are the implications of this?
Should I connect the hot feed to the shower direct to the hot pipe, or should I connect it after the T valve so it has hold and cold? This is what the connections to the taps look like:
Bath Feed.png (6.5 KiB) Viewed 1977 times
Am I OK to connect a mixer shower to this (such as: https://www.diy.com/departments/mira-at ... 639_BQ.prd)
Thanks!
Jim.
It is currently Fri Dec 27, 2024 5:00 am
