Upgrade Gravity Fed Thermostatic Bar Shower Valve
trevbul1
by trevbul1 » Sun Aug 12, 2018 11:18 am
HI all,
I have moved into a house with a gravity-fed thermostatic bar shower valve which is barely a trickle and desperate for a pump. There is a dedicated 22mm feed from the cold water tank and a shared 22mm feed from the hot water cylinder in the roof, so I will fit an ******* flange to feed the pump.
However, the last 1.5 metres of pipe, hot and cold, have been reduced to 15mm.
I am concerned that this will reduce the benefit of the pump - can I replace the connections in the back of the shower valve with 22mm or will I need a new shower valve?
Thanks in advance for any advice!
Trevbul1
Tall bloke
Re: Upgrade Gravity Fed Thermostatic Bar Shower Valve
by Tall bloke » Fri Aug 31, 2018 5:55 pm
Th shower should run just fine with 15m piping. Sounds like the problem is elsewhere.
trevbul1
by trevbul1 » Sat Sep 01, 2018 10:17 am
Thanks, Tall Bloke, pump now installed and it's all good even with the 15mm connections. Don't know why the pump manufactures say it must be 22mm all the way if it reduces to 15mm when it reaches the shower valve anyway, but hey ho, it works way better than it did.
It is currently Wed Dec 04, 2024 8:27 am
