22mm Flexi and Reducer or 15mm Flexi to Bath Tap?
Niko
by Niko » Thu Sep 13, 2018 8:57 pm
Bit of a dumb question possibly, but wondering if using a 22mm Flexi from bath tap and reducing down to 15mm feed at supply is going to be any better than just using a 15mm Flexi from supply to tap?
I know the bore of the 22mm pipe is bigger, but wondering if this is actually going to make much difference to flow at the tap given the 22mm is only for the last few inches and the rest is 15mm copper?
System is a new decent flow rate WB combi.
Many thanks
KitchenGuy
Re: 22mm Flexi and Reducer or 15mm Flexi to Bath Tap?
by KitchenGuy » Sat Sep 15, 2018 1:45 am
No difference at all. 22mm pipes were for increased flow off gravity systems. You have a combi so the hot runs off mains pressure and that won't change and neither will the flow one jot no matter which pipe you put on if it's coming in off a 15mm pipe. If you decide the 15mm flexi try not to avoid the small bore type though.
Niko
by Niko » Sat Sep 15, 2018 10:28 pm
Righto thanks. Think I'll go for the 22mm as the bore will be bigger.
It is currently Fri Nov 22, 2024 1:14 pm
