Wall Fixings Near Consumer Unit
Gareth176
by Gareth176 » Fri Sep 14, 2018 1:01 pm
I want to put a shelf up in my home office, on a wall which also has the consumer unit on it. Is this a total non-starter, or could I safely avoid drilling into a cable by using those plasterboard fixings which screw into the wall? I’ve tried using a Bosch detector to map where the cables are, but it seems to light up like a Christmas tree without any pattern I can map out (maybe it’s just cheap !).
Thanks in advance for any advice.
Re: Wall Fixings Near Consumer Unit
by Mr White » Fri Sep 14, 2018 6:36 pm
All cable "detectors" have the same problem, they are a waste of money.
Ideally the cables to your consumers unit should run vertically up or down to the consumers unit. The problem is you should never assume anything.
I would also pint out that having a shelf near a consumers unit will be a pain should the consumers unit need to be inspected, as it will no doubt hinder things.
As for finding where the cables run, I can only suggest you make an exploratory hole and see what you find.
It is currently Sun Jan 26, 2025 2:28 am
