Rendering brick gable wall: Should I PVA the painted area, or should I just soak it?
dan32
by dan32 » Fri Aug 31, 2007 7:20 pm
Please help i have a brick gable wall to render a small patch under the window is already rendered with a slightly textured finish which is painted(a bit like it was done with a terrroline flicker).
Do i pva the painted area, or should i just soak it. As i am going to on the rest of the brickwork before applying scratchcoat
It is currently Sat Nov 23, 2024 7:58 pm
