Wiring on a Honeywell dt90e Thermostat to Replace old Manual Dial
bobthompson1
by bobthompson1 » Mon Oct 08, 2018 8:31 pm
I have a manual dial thermostat that I want to change to a Honeywell dt90e the wiring is as follows red to No1 yellow/green to no3 blue to no4 is it possible they have used the earth wire as the switched live as the blue is the neutral
Re: Wiring on a Honeywell dt90e Thermostat to Replace old Manual Dial
by Mr White » Mon Oct 08, 2018 10:51 pm
From your description it does sound like it. Are you sure it is yellow / green not just yellow?
If it is the earth core, it is dangerous and should be corrected.
bobthompson1
by bobthompson1 » Tue Oct 09, 2018 10:29 am
Definitely green and yellow it does look like it's sleeved. on the dt90e you do not need a neutral if I marked it appropriately could I use the blue wire as the switched live
by Mr White » Tue Oct 09, 2018 8:06 pm
So long as the earth is used for its correct purpose, any of the other cores can be used for any purpose so long as they are tagged / marked at both ends.
bobthompson1
by bobthompson1 » Wed Oct 10, 2018 6:24 am
Thanks will have another look at it
It is currently Sat Jan 11, 2025 7:59 pm
