Wallpapering a Concave Wall and Paper not Sticking to Curve
Candelle
by Candelle » Fri Oct 12, 2018 12:13 am
I am cross-lining a small cloakroom prior to wallpapering with a vinyl. I am having problems and could do with some advice please, if possible!
The room has a wall that curves from a sloping roof and goes into to a concave wall (approximately 1 m 10 wide). This ends at mid-wall height at a shelf below which is the loo.
The walls are gloss paint (which I had previously wallpapered without too much difficulty) but couldn't initially get this lining paper to stick.
I then lightly sanded the wall and then applied a light coat of Zinsser 123.
The lining paper is now adhering well everywhere but I can't get it to stick in the curve. I slit the paper at the sides hoping to allow for the bend but after an hour or two, I just get a huge air bubble (despite it initially sticking well).
Is there a way of getting the lining paper (and also the vinyl yet to go on top) to stick - and stay stuck?
Help gratefully received!
Regards
Candelle
collectors
Re: Wallpapering a Concave Wall and Paper not Sticking to Curve
by collectors » Sun Oct 14, 2018 3:35 pm
Personally i would sand the wall with about 60 grit sandpaper & use the same wall paper paste to size the wall & paste the lining paper & leave for 10 mins before putting the paper on the wall. If its a inwards concave wall?, it could be also the paper is shrinking as it drys. I have seen decorators having similar problems & having to cut the lining paper & repasting the paper & after it dry using fine surface filler on the gap.
gc1967
by gc1967 » Tue Feb 19, 2019 10:59 pm
When you come across situations like this paste is just not strong enough, buy good border/overlap white adhesive and apply to the part that wont stay down and roll out with seam roller, always works for me and I have been a Painter and Decorator for 33 years
Candelle
by Candelle » Wed Feb 20, 2019 9:40 am
Thanks gc1967.
Actually, I have not yet finished this room as I have been concentrating on others.
I did sand the whole room down and have applied lining paper over the flat walls but have not been brave enough to give the curve another go - yet... (it came away at the apex at my first attempt, hence my plea for help) I am in the middle of another project but this is on my 'to do' list for late Spring (I work v slowly!!).
When I come to start it I'll remember to use overlap adhesive and keep my fingers crossed!
Many thanks for your help.
Regards
Candelle
It is currently Fri Nov 22, 2024 9:12 pm
