Removing Thumb Turn From Lock
Lewi777
by Lewi777 » Thu Oct 18, 2018 6:08 pm
I have a pvc door with an ABS lock with a thumb turn on the inside (of the house). Is it possible to remove the thumb turn element so that it works like a normal lock and if so, how do you do this?
Thanks!
Lewi
KitchenGuy
Re: Removing Thumb Turn From Lock
by KitchenGuy » Thu Oct 18, 2018 11:36 pm
You can remove the thumb turn by taking out the cotter pin but it won't give you access for a key. I don't know why you would want to though. Having a thumb turn is much safer in the event of fire or other emergency, you don't want to be looking for your keys at such a time. If you have to change to a key access inside, it is far easier just to change the Euro cylinder (lock barrel) usually around £5 to £15 and upwards, depending on make and type of cylinder you buy. This can be done in minutes but it mean having new keys.
It is currently Thu Nov 14, 2024 9:47 pm
