Glass Block for External Wall advice Needed
Colink
by Colink » Sun Oct 21, 2018 1:15 am
Planning to install glass block in a 9" solid wall. New cut out.
4 wide, 8 high
Preference is to make blocks flush with outer brick. Any issues with this?
Planning using suitable mortar and steel rods.
Any deed to cut a rebate in brickwork or can I
make cut out same W & H through full 9"?
Recommendations where to put a DPC, if required?
If blocks will be flush with brickwork (replacing the cut out brick) is there any need for a sill? (Will be adding a concrete head above the blocks).
Any other important things to consider?
Thanks ColinK
It is currently Sat Nov 23, 2024 10:50 am
