Reopen a Closed up Doorway and How to do This
trichb
by trichb » Tue Oct 23, 2018 10:40 am
THe previous home owners closed up a doorway with (I am pretty sure) breeze blocks.
I want to reopen this doorway.
Is it as simple as cutting the hole and tidying it all up afterwards, door etc?
I am fairly sure it is a non load bearing section, if that is the case then I assume no lintel required?
Just cut the section out?
What tool should I use for the job?
Any advice and guidance gratefully received...
It is currently Sun Dec 22, 2024 3:43 am
