Bedroom Door Latch not Going in?
Rosscohen
by Rosscohen » Wed Oct 24, 2018 8:47 am
Hi there,
My bedroom door latch does not go all the way in even when the handle is fully turned. Please can someone suggest a solution to make it go all the way in as it makes it very difficult to open and close the door. It is a normal door handle .
Ross
KitchenGuy
Re: Bedroom Door Latch not Going in?
by KitchenGuy » Wed Oct 24, 2018 10:29 pm
Most of them don't go all the way in. You will have to rebate the striker plate in a bit deeper by the looks. If it's just catching a fraction you may be able to just tap in the plate a bit with hammer and a block of wood "as not to scratch the plate" and then tighten the two screws holding it in.
It is currently Thu Nov 14, 2024 10:24 pm
