Brick and Lime Mortar Repair in Winter
Stowman2018
by Stowman2018 » Sat Oct 27, 2018 10:44 pm
The wall of my house has what looks like a hole in the brickwork and seems to have caused damp and water damage inside the property. I think to fix this I need to replace the damaged brick and apply lime mortar.
I've only just brought the property so don't know the full history of the issue (I suspect it has been like this for a while) but want to get it fixed ASAP so I can start work on the internals of the house without the risk of further water damage. My concern is that as the house is Victorian it has lime mortar and repairing this now as temperatures drop to below 5C might create issues with the mortar freezing before it has fully set. I'm told that I should really wait until spring if using lime mortar.
I believe I need to avoid using anything with cement in it as this isn't breathable (photo shows a previous repair that has failed with what looks like cement).
My question is whether there is a way to repair this correctly in cold conditions and if not and I have to wait until spring is there a temporary repair I can do to prevent water getting in? Someone suggested expanding foam but I'm not sure this is a good idea.
Images attached both external and internal, The internal is the ceiling on the ground floor below the hole. The damaged brick is to the left of the window sill. The brickwork around the boiler flue and overflow pipe has gaps too and needs repair.
Damp on ceiling below hole
Hole in wall to left of window sill
KitchenGuy
Re: Brick and Lime Mortar Repair in Winter
by KitchenGuy » Tue Oct 30, 2018 11:46 pm
It is the case you shouldn't lay it when too cold. Min 5 degrees and rising is usual. No need to wait until spring though, just wait for a couple of mild days and it will be fine.
Stowman2018
by Stowman2018 » Wed Oct 31, 2018 9:16 am
Thanks KitchenGuy. Would you agree to use lime mortar or is cement OK?
collectors
by collectors » Wed Oct 31, 2018 10:06 am
On the damp patch side . Are you living in a flat as i noticed two flu,s outside. Is it a possibility there is a kitchen/bathroom above with a sink or washing machine as its unusual to get damp half way down the house. Worth a look.
Stowman2018
by Stowman2018 » Wed Oct 31, 2018 7:29 pm
There is another flat above. Their boiler, sink and washing machine are directly above the mark in the ceiling. I've been up and checked since making my original post and there are no signs of a leak (no stains, dampness etc). So my only theories are (a) it's an old issue that has been fixed but the previous owner, being a landlord who neglected the property, never fixed the stain (b) it's to do with the hole in the wall outside.
Either way the hole in the wall needs fixing so I'm curious about how best to do this.
It is currently Fri Nov 22, 2024 6:44 am
