Cause of Worn Enamel Below Bath Drain Overflow
Radge70
by Radge70 » Fri Nov 02, 2018 3:58 pm
I'm new to the forums and have a question whereby the answer is probably obvious but I thought I'd check first...….
As per the attached photo, the enamel on my bath has worn below bath drain overflow. The bath is in a property that I rent out so I am unable to monitor what's happening but there doesn't seem to be any obvious leak coming from the overflow.
Is it a case of replacing the overflow or is there a quick fix that might work? The reason I ask is because I am about to get the bath resurfaced and don't want this to happen again once that's done.
Just to complicate things a bit though, I have recently sealed and painted the bath panel so I am reluctant to take it off to replace the overflow!
Any ideas welcome.....
It is currently Sun Nov 24, 2024 10:02 pm
