Fill Hole Around a Radiator Pipe
osullivj
by osullivj » Tue Nov 27, 2018 7:36 pm
Can someone advise on the best way to fill in around a hole around a radiator pipe? See picture attached
Could I use something like this https://www.polycell.co.uk/product/poly ... polyfilla/ or should I get some form of patch?
Jerry
KitchenGuy
Re: Fill Hole Around a Radiator Pipe
by KitchenGuy » Sat Dec 01, 2018 12:24 am
Easiest way is just to fill it with any filler, sand back best you can and cover it with a snap on talon which will cover most of the filler. https://www.screwfix.com/p/talon-15mm-p ... pack/19706 If you look around you can even find larger diameter ones to completely cover the filler.
It is currently Thu Nov 21, 2024 9:45 pm
