Outside Light Trips Electric After Changing it?
mark2kooki
by mark2kooki » Mon Dec 03, 2018 2:24 pm
I had an outside light fitted years ago but never used. Anyway i replaced it with a new one. This one is different as the switch live was part of the light but this one isnt.
Followed a diagram online and it only worked whe the hallway lights where turned on.
so the mcb had a spare light fuse so i have rewired it direct and it now trips the mcb.
Have followed the diagram that is enclosed so i am very confused
Re: Outside Light Trips Electric After Changing it?
by Mr White » Mon Dec 03, 2018 6:53 pm
Your drawing appears to be correct. With that in mind your wiring or your connections must be in error.
As anyone offering advice like myself is sitting at a keyboard it is not possible to physically see what it is that is wrong, so I can only suggest you check your connections again, also make sure that when securing and "lids/covers" you check to see that they have not trapped or squashed any cables, as this can cause in a short circuit.
mark2kooki
by mark2kooki » Tue Dec 04, 2018 11:37 am
pictures of the outside light the junction box
the junction box wires below
Bottom left is the outside light
right is the power
leftis the switch
It is currently Sat Jan 11, 2025 8:50 pm
