What Roller to use for Pasting the Wall?
The_mechanic
by The_mechanic » Wed Dec 05, 2018 6:50 pm
Quick question, what kind of roller do you use for paste the wall? I was thinking foam. Sensible experience based answers please.
Hugh Schkok
Re: What Roller to use for Pasting the Wall?
by Hugh Schkok » Thu May 23, 2019 10:07 pm
I have a 9" lambs wool roller and that gives a good even covering accompanied with a radiator roller for the edges. I found foam rollers push the material away and often find areas have dried out before you come to put up the paper, where the material is thinner. Lambs wool dont do that and when you clean it out put some hair conditioner on the roller it will keep it soft and fluffy for next time.
Hugh
It is currently Fri Nov 15, 2024 7:14 am
