Old Loft Conversion Causing Ceiling Beams to Bow
smithynumerouno
by smithynumerouno » Tue Dec 11, 2018 12:27 pm
I have recently ripped down old lath and plaster ceilings and replaced them and double boarded. Above this, is a large loft conversion (converted years ago - with little or no regs). The issue is, that the weight of this has caused a lot of the ceiling joists (4x2) to bend in the larger rooms (5x5 meters). The worst was probably a few inches lower than the outer joists, which as a result, creates a sloping floor in the loft space.
In hindsight, I should have strengthened these prior to re-boarding, but was limited on time. Also, without tearing out the whole loft conversion, it seemed a mammoth task to add in new beams the full length.
I want to chipboard out the loft space (currently thin floor boards).
My thoughts are:
1. to level out the sloping loft floor with plastic noggins on top of the existing thin floorboards. Then chipboard over the top. I know this will add more weight but may spread the load of anything that is up there? - is this the best way to level it (without a leveling compound)?
2. Add battons to the sides of existing joists, at the sections I can access?
3. Insulate between the joists (currently nothing), by lifting the floor boards. To help with heat retention. Would I be better off with celotex (or equivalent) or use a loft roll / rockwool (or equivalent)?
Any other Ideas of what I could do - without getting a full loft conversion with steals and new 8 x 2 timber beams?
Your help is greatly appreciated.
It is currently Sun Dec 22, 2024 8:58 am
