Two Sets of Wires For Outdoor Light and how to Connect Them Correctly
mrfixituk
by mrfixituk » Mon Dec 17, 2018 2:19 pm
Looking to fit a standard light. Upon removing the old light there are two sets of live, netural and earth. I doubt they will all fit in the terminal block. How do I join/connect them?
Re: Two Sets of Wires For Outdoor Light and how to Connect Them Correctly
by Mr White » Mon Dec 17, 2018 10:19 pm
You have to connect the new light in the same configuration the old one was. If the new light does not have enough space, then you will have to install a weather proof junction box where the light was and run a short cable to where the new light is.
This way you have enough room to connect your original two cables and a new third cable to connect to the light.
If it helps, your "problem" is quite common, but being as it is an external light means a weather proof junction box is required if it were indoors other methods are often used.
It is currently Mon Nov 25, 2024 3:07 am
