garage door mechanism
durham
by durham » Sun Sep 02, 2007 8:52 pm
a friend has trouble with garage door mechanism or pulleys.
single door, metal, canopy type, spring above door, may be Henderson but not known.
Cable on one side slack or off pulley wheel or cone making it difficult to open.
Can anyone help please
Oddbod
by Oddbod » Sat Sep 15, 2007 11:10 am
Hi. Not really my field, but it sounds to me like the door and/or frame is twisted somewhere.
A tape measure and a level should identify the problem nicely.
durham
by durham » Sun Sep 16, 2007 10:58 am
Thank's for reply oddbod but I really think it is something to do with the pully wheel or cable
ANY ONE ELSE OUT THERE
durham
ANONIM ONE
GARAGE DOOR GEAR
by ANONIM ONE » Fri Nov 02, 2007 10:26 pm
IF ITS A CABLE ON TWO CONES AT EACH SIDE WHAT YOU DO IS TAKE THE TENSION OFF AND WIND THE CABLE TO THE OUTSIDE OF THE CONE ON BOTH SIDES
THEN PUT THE TENSION BACK ON PULLING THE CABLE TIGHT
ADJUSTING THE TENSION ON SPRING
THAT WILL STRAIGHTEN UP THE DOOR
LET ME KNOW IF THAT SOLVES IT
It is currently Sun Dec 22, 2024 12:44 pm
