Floor Slab Repair for Kitchen Floor in newly Purchased Property
Tomoe19
by Tomoe19 » Fri Jan 04, 2019 11:37 am
Hi all,
I have just purchased a property and there are some repair works that need completing on the kitchen floor. I have attached photos of the issue and would like some advice on where to start with the repairs. I have looked around online and it seems like a concrete filler would be acceptable? The hole that can be seen is around 3in deep and 2in wide.
The wooden door frame will eventually be replaced when we have a new back door fitted. It appears as if its been damp for a while and starting to rot. In the mean time can anyone advise the best way to repair this so o can then level it off and get some flooring down.
Tomoe19
Re: Floor Slab Repair for Kitchen Floor in newly Purchased Property
by Tomoe19 » Sun Jan 06, 2019 9:52 am
Further to this it seems like the cavity gap is the hole that's exposed between the door frame and the edge of the slab.
Woodpecker Flooring
by Woodpecker Flooring » Fri Jan 18, 2019 5:09 am
Is that the only area with gaps?
It is currently Tue Jan 07, 2025 2:14 am
