Removing and Draining Radiators to Redecorate Behind Them
Chintan_uk
by Chintan_uk » Thu Jan 10, 2019 7:57 pm
I am having trouble draining a radiator to paint behind it.
I have turned the thermostat valve to the * position and turned the other side all the way to the right. It is stone cold after the heating came on.
I get water coming out of the air release valve at the top. After about 30 mins it hasn’t stopped.
Have I missed a step? Any help would be appropriated
gc1967
Re: Removing and Draining Radiators to Redecorate Behind Them
by gc1967 » Mon Feb 18, 2019 11:23 pm
If the radiator has a thermostatic valve on it, you need the screw on cap that came with the thermostatic valve, you unscrew the valve and then screw the cap on its place and that pushes the pin down and stops the water flow, sometimes putting a small coin in the cap before screwing onto valve is a good idea.
The other way is leave the radiator on and use a paint rad roller with a long arm.
It is currently Tue Nov 26, 2024 1:43 am
