New Concrete Exposed to Elements and Soaking up Water?
russ_fae_fyvie
by russ_fae_fyvie » Sat Jan 12, 2019 8:17 pm
I am new to this Forum so please excuse any stupid questions !
I am just embarking on our 2nd (and last!) self build and am Project Managing it.
My builder is totally competent o I am not questioning his work, but I wondered if someone could help with my thoughts on the concrete slab just laid.
Basically its a standard 150mm slab (with rebar and DPM) which was poured about a month ago.
The garage itself will be erected on the slab in another months time so I was worried that during that time of it being under the weather, it would soak up all the rain that can be thrown at it.
So today I covered it with a tarp, put blocks under the tarp to its not totally lying on the slab, to prevent what will probably be a months worth of rain getting onto the naked slab.
So basically is that ok or is it likely to make things worse if the concrete sweats ?
thanks in advance
collectors
Re: New Concrete Exposed to Elements and Soaking up Water?
by collectors » Mon Jan 14, 2019 9:35 am
Concrete will only soak up water in the 1st day after the pour. After this, I wouldn't worry. To prove a point, next time you have a dry'ish day, drill a NO:6 hole under where the bricks are being laid & i bet you drill straight into dry concrete within a few millimetres.
russ_fae_fyvie
by russ_fae_fyvie » Mon Jan 14, 2019 3:39 pm
collectors wrote:Concrete will only soak up water in the 1st day after the pour. After this, I wouldn't worry. To prove a point, next time you have a dry'ish day, drill a NO:6 hole under where the bricks are being laid & i bet you drill straight into dry concrete within a few millimetres.
Thanks!!
It is currently Fri Feb 07, 2025 10:44 am
