Dimmer Switch Wanted to Replace Existing Switch
RAC
by RAC » Thu Jan 17, 2019 9:40 pm
Hi –
I have a standard light switch in my living room (image below). The three switches are independent from each other and operate a wall light and two ceiling lights.
Each light has LEDs and the box they came in says they are dimmable.
Is there a good quality dimmer switch on the market that would directly replace the current three switches?
Thank you.
Wall switch
Wall switch
Re: Dimmer Switch Wanted to Replace Existing Switch
by Mr White » Thu Jan 17, 2019 10:40 pm
In order to "dim" a lamp, some electronics are required. These electronics (No point in going into detail) require more physical space than an on/off switch requires. This means that there is NOT a direct replacement for the switch you have that can dim lamps.
The box that the switch you have is mounted on is too small, it could be changed it to a "double" box and then you can buy a 3 gang* dimmer switch which would fit the new box. (But I would recommend you get a competent person in to do it for you)
* Gang refers to the number of "buttons or switches"
RAC
by RAC » Wed Feb 06, 2019 4:20 pm
Thank you for the detailed reply, most useful.
It is currently Wed Jan 08, 2025 5:51 am
