Persistent Dripping Tap Even After Changing O-Rings
mrdo
by mrdo » Wed Jan 23, 2019 9:41 pm
Hi there,
I have a persistent dripping tap. I've changed the o rings which has actually made things worse.
I've read that some taps have cartridges that might need to be changed but I can't tell if this applies to me or whether the issue is the new o rings which were a tight fit.
I have attached a photo of the tap as I can't see any make or branding on it.
Any help gratefully received, thanks in advance.
It is currently Fri Jan 03, 2025 2:15 am
