Low Level Headboard Tray and Mortar Vs legs
Teessider66
by Teessider66 » Tue Jan 29, 2019 9:48 pm
I'm replacing my old shower with a low profile resin tray. I've read up that I need to replace the (dodgy) chipboard floor with 18mm marine ply which isn't a problem, and want to lay it as low as possible so am putting the waste under the floor.
What I have read up is that the tray should be laid on a 10mm mortar base to ensure all the tray is supported so it doesn't crack. However, if I want to raise the tray I can use legs, and there seems to be typically 5 legs, one per corner and one i the middle.
So, how is 5 legs OK, but if laid on boards it needs 10mm mortar?
Supplementary questions...
Does the 10mm mortar raise the tray so there is a gap to seal, or is it all inside the tray edge?
How much mortar do I need for a 1400x900 tray?
It is currently Thu Dec 05, 2024 3:18 am
