Is This a Load Bearing Wall and can I Remove it?
Andrewnovice89
by Andrewnovice89 » Tue Feb 05, 2019 11:38 pm
Hi all,
I am going to take an interior wall down. Have had conflicting views on whether this wall is load bearing (from different builders)
I drilled into the ceiling to take a look.
First image is directly in front, this appears like joists that run along the same direction as the wall (sounds good!).
But the second pic is if I turn the camera 90 degrees to the right, this is along the wall and there appears to be brick work.
What do you think?
It is currently Mon Nov 25, 2024 4:17 am
