Step out/offset Hinges for Bathroom Cupboard
khblue
by khblue » Sun Feb 10, 2019 1:05 pm
I'm oping someone can point me in the direction of the right product here.
I'm going to hang a mirror cupboard door (15mm thick) across the corner of the bathroom directly onto the wall with no cupboard behind it and I want it snug against the wall at the edges, not stepped off on a baton.
So the angle to the wall at the hinge will be 60 degrees. The door is only going to open 30 degrees(ish) before the edge of the door hits the wall.
Is there a hinge that I can use that closes to 60 degrees and will swing away from the wall as it opens to give clearance for the width of the door? Kitchen door hinges only seem to close to 90 degrees.
Ideally the hinge will be hidden behind the door, not visible in the bathroom.
It is currently Thu Jan 09, 2025 2:27 am
