Wiring in a lighting sensor to existing outside lights.
Gaspin
by Gaspin » Mon Sep 03, 2007 6:42 pm
I have recently installed 2 outside lights which are about 6ft apart and on the same circuit and I would now like to wire in a sensor, so that the lights will activate for a short while when someone approaches them. These lights are on an outbuilding and I do not need to incorporate a timing device or dusk to dawn facilitly but only need the existing manual on/off mechanism. I would like advice on what type of unit to buy, taking into account the above, and how to install it into the existing circuitory.
Thanks.
BLAKEY1963
Re: Wiring in a lighting sensor to existing outside lights.
by BLAKEY1963 » Tue Sep 04, 2007 1:09 am
[quote="Gaspin"]I have recently installed 2 outside lights which are about 6ft apart and on the same circuit and I would now like to wire in a sensor, so that the lights will activate for a short while when someone approaches them. These lights are on an outbuilding and I do not need to incorporate a timing device or dusk to dawn facilitly but only need the existing manual on/off mechanism. I would like advice on what type of unit to buy, taking into account the above, and how to install it into the existing circuitory.
Thanks.[/quote]
GASPIN
RESPECT U HAVE HAD A GO BUT THIS IS IS NOTIFIABLE WORK
AND YOUR PART P SPARK SHOULD ADVISE.
READ DOC S PART P ADVICE SECTION.
BLAKEY1963
It is currently Tue Nov 05, 2024 4:27 am
