Grub Screws in Door Handles Keep Coming Loose
HarryCrowther
by HarryCrowther » Fri Mar 29, 2019 3:32 pm
The grub screws in my door handles keep working loose.
Which is the best type of grub screw to use? Is the cone point supposed to hold better than the dog point or cup point?
Thanks,
Harry
Sometimewoodworker
Re: Grub Screws in Door Handles Keep Coming Loose
by Sometimewoodworker » Sat Mar 30, 2019 12:56 am
HarryCrowther wrote:Hi,
Thanks,
Harry
I wouldn't use a grub screw (slot head) instead use a Socket Setscrew (Allen key) and a Knurled Cup point together with Loctite® 222 or LOCTITE® 243
But not LOCTITE® 263 (red)
ZaneC
by ZaneC » Tue May 14, 2019 1:29 pm
I'm having the same issue with door handles, when I took it apart, it looks like the tip of a cone point has been bent. Could it be that the metal was too soft?
Does anyone know where I can get a knurled cup point set screw in hardened steel please?
HarryCrowther
by HarryCrowther » Thu May 16, 2019 10:05 am
Sometimewoodworker wrote:Does anyone know where I can get a knurled cup point set screw in hardened steel please?
I got my cup point grub screws from Accu : https://www.accu.co.uk/en/14-cup-point-set-screws.
It is currently Fri Nov 22, 2024 11:10 am
