Hello all,
I'm planning to fully renovate a house, turning it to a 4 bedroom HMO
The renovation will include fully refurbishment of the house internally and externally, upgrading the kitchen and WC's, wiring, heating system etc.
The building costs will be around 30-35K.
Currently my builder based his costs using the detailed plans used for building reg control, but i'm worry that calculating building cost only by visiting the site and using the detailed architect plans won't be accurate.
Should i need a construction plan from the architect for this scale of work?
Should i need a Quantity surveyor or it is too simple project for that?
Should i use JCT contract with dated work millstones with Liquidated Damages clause or it's a bit overstretch ?
Is the project's size o determine if i need Quantity surveyor and construction plan? are there any other considerations?
Thank you,
