Velux Window Leak in Sandtoft Flat Roof
rf22095
by rf22095 » Mon Apr 22, 2019 9:41 pm
Ive installed a velux window in a self build roof this weekend which has a flat sandtoft 20/20 concrete interlock tile.
Ive fitted the recommended flashing from Velux but ran some water over it and found a very slight drip in the one corner.
I think this is because when I cut the foam back on the flashing I tried to cut it as low as I could to try and get the tile covering the flashing as flat as possible. I can now see that the there is a cap between the foam and tile close to the headlap of the tile.
I was thinking of filling these gaps with expanding foam as a solution, will this last and does anyone have any experience of a similar problem?
Thanks in advance.
Makie-
Re: Velux Window Leak in Sandtoft Flat Roof
by Makie- » Mon May 20, 2019 1:26 am
When you say you ran some water over it, what exactly did you do? Did you use a hose or did you pour it and if so in what way did you do either?
It is currently Mon Dec 02, 2024 8:30 pm
